Home > Maintenance & Modifications > Washer jets from a dismal squirt to power.... |
Lightwater Member Since: 28 Jun 2020 Location: Sydney NB Posts: 72 |
I only just recently drilled out the Freelander jets, they were corroded & a pile of crud came out. I only ever put clean water in tank with some debugging detergent. So don't get it.
While at it I drilled out the 4 holes, can't quite remember the starting point, but I think about 0.55mm (I have drills down to 0.3mm, they are tiny) & drilled up in steps of 0.1mm stopping at 0.85mm. you do need to drill up in steps to avoid snapping a drill bit. beyond 0.85mm the pressure was going to drop a bit too much I feel. With a 5L tank there's still enough water between refills. But now I am happy with the increase volume on the windscreen. Use some cutting fluid on the drill bits. Visitor - Freelander owner |
17th Nov 2023 2:29pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
Instead of using a detergent in the washer fluid, add a few tablespoons of white vinegar: it'll keep the lines clear and give you a very clean & strek-free windscreen --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
17th Nov 2023 4:17pm |
