![]() | Home > Technical > High HTHS oil |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4248 ![]() ![]() ![]() |
Maybe filter your search to ester-synthetic oils. These are the most expensive, highest quality and I think tend to be HTHS. Options are limited though. https://www.opieoils.co.uk/c-953-ester-syn...tityids=53
BMW LL04 spec is quality synthetic oil that was used in the pre-fuel economy days a few years ago. Something like this https://www.opieoils.co.uk/p-92073-motul-8...e-oil.aspx Look at other long-life full synthetic oils that don't say anything about fuel economy on the can. Maybe the ones intended for VAG variable service intervals from a few years ago. Maybe drop an email to Opie Oils, they are usually helpful with technical queries. 2007 110 TDCi Station Wagon XS |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2456 ![]() ![]() ![]() |
Acea A3/B4 HTHS cP ≥3.5
SAE 0W-30 group IV base oils (PAO) SAE 5w-30 group III oils (usually HC. Not "true" synthetic) Puma 110" SW ............................................................. Earth first. Other planets later |
Rednaxela Member Since: 23 Sep 2019 Location: UK Posts: 41 ![]() ![]() |
Thanks for the input.
I went today to a near supplier who I can't really beat for price, picked up some Millers 7625. That's fully synthetic 5w40, A3/B3. Interested to see how a 5w40 goes. |
Quite thick for a Td5. Anyway, only an oil analysis will tell how it went. Puma 110" SW
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4746 ![]() ![]() |
I am using this MANNOL Energy Formula FR 5W-30.
"Innovative energy-saving ester-containing fully synthetic premium engine oil specially developed for modern diesel engines and a number of petrol engines in FORD and VOLVO vehicles, considering the requirements for heavy-duty operation and extended engine oil change intervals. The oil can be used in petrol and diesel engines of European and Asian car manufacturers requiring API SN and ACEA A5/B5 oils. Product properties: - Ester components provide excellent anti-wear and anti-friction properties due to the exceptional durability of the oil film, which, combined with excellent pumpability, significantly increases engine life even in “start-stop” mode; - Significantly saves fuel due to the reduced high-temperature viscosity (HTHS) and excellent anti-friction properties; - Effectively protects the timing belt from wear, offers an increased total base number (TBN) and excellent compatibility with sealing materials, following additional requirements of FORD; - Provides easy, low-temperature engine starting due to its excellent pumpability and particularly turnability, which significantly reduces engine starting wear; - Effectively protects the timing belt from wear, offers an increased total base number (TBN) and excellent compatibility with sealing materials, following additional requirements of FORD; - A synthetic base guarantees low volatility and reduced operating consumption; - Excellent washing and dispersing properties, together with the highest thermal-oxidative stability, effectively prevent all types of deposits and keep engine separate parts clean throughout the oil change interval; - Due to its high thermal-oxidative stability, it resists ageing effectively, thus extending the oil change interval; - Suits bio diesel engines. Designed for diesel engines of passenger vehicles by FORD, VOLVO and GM, where SAE 5W-30 oil is recommended, which complies with the ACEA A5/B5 standard and meets FORD WSS-M2C913-D specification, as well as for petrol and diesel engines of these brands where previous specifications 913-C, 913-B and 913-A oils are recommended." Using it in two Puma 2.4 vehicles. No issues but I change yearly and always within specified guidelines. It is well priced. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
