Home > Td5 > Can’t switch the alarm off
Rivarama
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zermatt Silver
So I bought my defender (1998 early model TD5) over a year ago, and since then I never actually locked it or used the immobiliser.
For some reasons today I noticed that a red light appeared on the gauge board, which I assume must be the immobiliser / alarm.
I remember the seller telling me the car ECU was an upgrade unit and had the immobiliser disabled (which I was very happy about at the time).
Although I can start the car OK, the alarm goes off every time I open the driver’s door, and stops when I close it. For some weird reasons it doesn’t when I open any other door. I tried to play w the key fob to no avail (I just ordered new battery as I suspect the FOB battery died a long time ago).
Anyone knows how to disable the alarm manually/remove it all together? How can I tell if my FOB is working?
As you can see, my car was fitted with a button switch board. All the lights would usually go off when I take the key off the ignition, but I am now seeing that green light that stays on too… #confused !!
Post #1013808 3rd Nov 2023 5:29pm
4RF RDS
You’ll need to plug in a Nanocom to do what you are asking.
Maybe these pages might help? 🤷‍♂️
Good luck
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #1013932 4th Nov 2023 6:02pm
Rivarama
That’s super helpful, thank you !!
Post #1013941 4th Nov 2023 6:59pm
TexasRover
Does anyone know if that red light on the odometer is standard on all (and can be made to work through the connection plug)? Wouldn't mind an in-yer-face red light for some custom alarm, like low coolant etc.
Post #1013951 4th Nov 2023 8:31pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
not realy the answer but ...
hi,
I did have problems during months with the alarm of my defender td4 2,2 from 2012.
This only because after change the battery I did not actuate the alarm 5 tmes to synchronise the system
mayby this can help one day
Regards
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #1014012 5th Nov 2023 3:06pm
4RF RDS
Yes it is common to all Thumbs Up
I have one of these low coolant monitors in my Td5 CSW
https://www.td5spy.co.za/coolant_monitor 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #1014016 5th Nov 2023 4:19pm
