Home > General & Technical (L663) > Where to put my gas cap when refueling |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1421 |
I place mine in the semi circular cut out which I think is what you are alluding to, I know I have to slide the tether around sometimes to get it to fit correctly. Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
2nd Nov 2023 9:12pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3419 |
As above 24MY 90 D250 HSE, Tasman Blue
2nd Nov 2023 9:13pm |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 108 |
Excellent. Got it now. I was trying the wrong part of the cap, then I tried the tether itself (as another car of mine does). Thanks.
2nd Nov 2023 9:19pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1418 |
I put mine in the towing eye. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
2nd Nov 2023 10:02pm |
Your tether is probably stretchier than mine.
2nd Nov 2023 10:04pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2670 |
Mine just hangs on the tether, is that not what it’s for?
3rd Nov 2023 11:58am |
chpsk8 Member Since: 26 Sep 2023 Location: Midwest Posts: 45 |
So does the cap sit in that indent, or does the tether? I can never get any part of the cap to sit in the indent, it always falls off and bangs into the car. I’m sure I’m just doing it wrong.
3rd Nov 2023 12:56pm |
David007 Member Since: 26 Oct 2022 Location: Angus Posts: 111 |
This is mine and the cap sits in the indent. Hopefully you can see from the pictures how it should sit.
3rd Nov 2023 2:11pm |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1170 |
I just let it dangle, never bothered me....
3rd Nov 2023 2:28pm |
Yep, that's how mine fits Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
3rd Nov 2023 4:29pm |
Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 59 |
^^^as above sits on flap
3rd Nov 2023 4:46pm |
Ok, that’s what I keep trying. My tether has so much spring in it, it just pulls the thing off!
Maybe I’ll take a heat gun to the tether and see if I can get some of the spring out of it. Thanks for the clarification! |
3rd Nov 2023 5:29pm |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 432 |
Design flaw nr... ?? No Mud flaps for my 90.!
----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
3rd Nov 2023 7:18pm |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 285 |
I keep trying to sit the cap in that groove but as soon as I shove the petrol nozzle in the filler neck it knocks the cap off its perch!
3rd Nov 2023 8:22pm |
