![]() | Home > General & Technical (L663) > Where to put my gas cap when refueling |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
I place mine in the semi circular cut out which I think is what you are alluding to, I know I have to slide the tether around sometimes to get it to fit correctly. Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3427 ![]() ![]() |
As above 24MY 90 D250 HSE, Tasman Blue
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 109 ![]() ![]() |
Excellent. Got it now. I was trying the wrong part of the cap, then I tried the tether itself (as another car of mine does). Thanks.
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1439 ![]() ![]() |
I put mine in the towing eye.
Your tether is probably stretchier than mine.
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2693 ![]() ![]() |
Mine just hangs on the tether, is that not what it’s for?
chpsk8 Member Since: 26 Sep 2023 Location: Midwest Posts: 45 ![]() ![]() |
So does the cap sit in that indent, or does the tether? I can never get any part of the cap to sit in the indent, it always falls off and bangs into the car. I’m sure I’m just doing it wrong.
David007 Member Since: 26 Oct 2022 Location: Angus Posts: 111 ![]() ![]() |
This is mine and the cap sits in the indent. Hopefully you can see from the pictures how it should sit.
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1214 ![]() ![]() |
I just let it dangle, never bothered me....
Yep, that's how mine fits ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 61 ![]() ![]() |
^^^as above sits on flap
Ok, that’s what I keep trying. My tether has so much spring in it, it just pulls the thing off!
Maybe I’ll take a heat gun to the tether and see if I can get some of the spring out of it. Thanks for the clarification! |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 435 ![]() ![]() |
Design flaw nr... ?? No Mud flaps for my 90.!
----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 291 ![]() ![]() |
I keep trying to sit the cap in that groove but as soon as I shove the petrol nozzle in the filler neck it knocks the cap off its perch!
