Home > Series Land Rovers > Advice wanted to identify series engine
Bobtailkev
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Hi everyone,
I am looking for some advice, please. We have what we believe is an old Land Rover engine, which belonged to my late father-in-law. Sadly, we did not check with him before he passed away, exactly what it was. I have taken photos and hope that some of you with better knowledge than me can identify what it is.
With very many thanks in advance!
Kevin
Post #1013028 28th Oct 2023 9:44pm
It's certainly a Rover diesel engine but there are one or two features I don't recognise, such as the shape of the inlet manifold. It is possible it is from an FX4 taxi. I'm pretty sure it is a 2286cc, not the earlier 2-litre Series One version (which is relatively rare).
It is unlikely to be of any particular value, I'm afraid. It was a simple, solid, and reliable engine with remarkably little power by modern standards.
Post #1013033 28th Oct 2023 10:30pm
Dinnu
It could be an inlet manifold from a later 12J engine, unless the complete engine is from a very early 90/110. There were 2 variants of that engine, a 3 or 5 main bearing. I do not know how to identify without opening the sump and look at the crank itself, but perhaps the engine number, which was normally stamped on the left side of the engine casting could give a clue. In last photo, the broken tip of the dipstick is pointing to the location where the engine number used to be stamped.
Locally these engines are fetching some good money as they are getting rarer. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1013039 29th Oct 2023 4:17am
Looks like a 2.5 N/A to me. The design of the exhaust and inlet manifolds certainly matches. Darren
Post #1013048 29th Oct 2023 8:02am
Useful, thanks, I was unfamiliar with the manifolds (there's an experience/knowledge gap for me between the SIII and the 200TDI).
I think your "manifold" conclusion is likely to be definitive, although I thought that the large lifting eyes predated the 2.5 NA, earlier eyes could of course have been retrofitted..
Post #1013049 29th Oct 2023 8:08am
As you suggest, there's no guarantee that it's a Land Rover engine. It could be for a different application that warrants slightly different fittings. Darren
Post #1013052 29th Oct 2023 8:30am
Dinnu
Not to me.
The 2.5 N/A, aka 12J, fuel injection pump is belt driven, and is located longitudinally on the right side of the engine, same or similar location as the 19J, 200 and 300tdi.
The photos uploaded by the OP has the fuel injection driven by the cam shaft, where on the 12J, 19J and 200tdi you would find the vacuum pump.
There are also some differences in the engine block casting. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1013070 29th Oct 2023 10:11am
It looks essentially like a pre-1984 10J 2286cc diesel to me, but the pre-engaged starter and both manifolds are not what I would expect.
Could the starter and manifolds be off a 2.5? I imagine that they would fit.
Post #1013081 29th Oct 2023 11:27am
Dinnu
I once tried to fit a later type pre engaged started on a 10J, but did not fit. Cannot remember the details, but if I am correct it had to do with the ring gear rather than the flywheel housing. I do remember clearly that it fitted perfectly on my 19J.
That starter does look slightly different though, I am not familiar with the inspection cover for the brushes. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1013089 29th Oct 2023 1:33pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Can you see the engine number? Should be stamped on the block at the front above the dynamo. Euro-Leafing to infinity and beyond.....
Post #1013421 31st Oct 2023 7:44pm
Bobtailkev
Hi everyone,
Many thanks for your comments- I am going down to where it is this weekend so will do some investigating.
Kevin 👍😊
Post #1013452 1st Nov 2023 6:58am
