![]() | Home > Td5 > Front Cam Seal O-Ring Size |
It seems my front cam seal has started leaking. It was new not long ago and was a genuine part so I am loathed to spend £30+ on another genuine one. Does anyone know what size the o-ring on the seal is as I would like to try replacing this first?
Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
Yes please
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 544 ![]() ![]() |
5mm O-ring, 55mm internal diameter, 60mm external diam
Hope it helps |
Brilliant, cheers!
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17659 ![]() ![]() ![]() |
It can't be 55mm ID and 60mm OD if it is a 5mm section O-ring! 50/60mm or 55/65mm but not 55/60mm. ![]() |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 805 ![]() ![]() ![]() |
53 x 34 x 5 Nitrile 70
BS330N70 I have a couple here if you get stuck ![]() |
