Home > Td5 > Front Cam Seal O-Ring Size
rallysteve
It seems my front cam seal has started leaking. It was new not long ago and was a genuine part so I am loathed to spend £30+ on another genuine one. Does anyone know what size the o-ring on the seal is as I would like to try replacing this first?
Post #1013018 28th Oct 2023 7:45pm
htb2
Wales
Think I have a note of it in the shed will try and look it out the morn, your after the one that fits round the plastic cap.
Post #1013021 28th Oct 2023 7:58pm
rallysteve
Yes please Thumbs Up 02' 110 TD5 Double Cab Rebuild Thread
Post #1013026 28th Oct 2023 8:38pm
htb2
Wales
5mm O-ring, 55mm internal diameter, 60mm external diam
Hope it helps
Post #1013073 29th Oct 2023 10:25am
rallysteve
Brilliant, cheers!
Post #1013077 29th Oct 2023 11:00am
Hope it helps
It can't be 55mm ID and 60mm OD if it is a 5mm section O-ring!
50/60mm or 55/65mm but not 55/60mm. Sad
Post #1013080 29th Oct 2023 11:20am
rustandoil
53 x 34 x 5 Nitrile 70
BS330N70
I have a couple here if you get stuck Thumbs Up
Post #1013177 30th Oct 2023 10:11am
