- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
geobloke
Given your low low low fuel level I suspect that was the problem. However, I would begin with checking the fuel filter housing, these are known to corrode and allow air into the system.
Do you have access to an OBD code reader? It would be useful to check whether you have any recorded on the ECU.
At least it has not happened again
19th Oct 2023 2:12pm |
