- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
geobloke
![](templates/vbnew/images/spacer.gif)
Given your low low low fuel level I suspect that was the problem. However, I would begin with checking the fuel filter housing, these are known to corrode and allow air into the system.
Do you have access to an OBD code reader? It would be useful to check whether you have any recorded on the ECU.
At least it has not happened again ![Thumbs Up Thumbs Up](images/smiles/icon_thumbs.gif)
19th Oct 2023 2:12pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
