Home > Puma (Tdci) > Puma 110 Front Brake Calipers |
One is the left hand side and one the right hand side.
17th Oct 2023 12:19pm |
Oh hang on do you mean the difference between the part numbers... LR were excellent at superseding parts but not really changing them at all. The front brake calipers are a case in point. The vented calipers are the same right through the Defender range from, as you say, year dot through to the end of production. A side of that is the pads are the same as well.
17th Oct 2023 12:21pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8071 |
Front calipers are same throughout less vented or solid option Cheers
17th Oct 2023 12:28pm |
Albarker55 Member Since: 02 May 2022 Location: Fleet, Hants Posts: 22 |
Sorry my explanation was not clear. I would like to understand the difference, if any, between LR061253 and SEB500460, and LR061254 and SEB500470.
I think you have answered my question in your other reply and it looks like my logic was OK! |
17th Oct 2023 12:30pm |
James - Many thanks. Looks like the part numbers change only to protect the profit margins!!
17th Oct 2023 12:33pm |
And probably changes in suppliers etc as well.
17th Oct 2023 12:37pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1089 |
Looking at the calipers I am getting the distinctive impression that the difference between vented and non vented disc is a space piece fitted between the two halves. So really even they are the same no? |
17th Oct 2023 12:51pm |
Yes they are the same. Just the addition of the spacer and gallery seals.
17th Oct 2023 12:52pm |
Geobloke - Agreed re supplier changing = PN change
17th Oct 2023 1:19pm |
