Home > Puma (Tdci) > Puma 110 Front Brake Calipers
Albarker55
2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Grateful for some help and clarification of front brake calipers please. I have a 2015 110 XS and I need to change my front pair out due to one seized piston on either side. Can refurb these at a later date. That is the easy bit! When I check the LR on-line parts, the replacement calipers are shown to be LR061253 and LR061254. These are like hens teeth and cost a second mortgage! Delving a little more, I see that the earlier PNs are SEB500460 (G suffix for the AP version) and SEB500470 (again G suffix for the AP version). Please would someone tell me what the difference is between these 2 sets of PNs. Looking at the attachment points on the swivel pin housing nothing has changed there since the year dot. Therefore, my logic says that I can fit the SEB500460G and SEB500470G PNs without any problem. Please tell me if I am missing something.
Thanks in advance
Post #1011541 17th Oct 2023 12:05pm
geobloke
One is the left hand side and one the right hand side. Thumbs Up
Post #1011542 17th Oct 2023 12:19pm
geobloke
Oh hang on do you mean the difference between the part numbers... LR were excellent at superseding parts but not really changing them at all. The front brake calipers are a case in point. The vented calipers are the same right through the Defender range from, as you say, year dot through to the end of production. A side of that is the pads are the same as well.
Post #1011543 17th Oct 2023 12:21pm
jst
Front calipers are same throughout less vented or solid option Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1011544 17th Oct 2023 12:28pm
Albarker55
Sorry my explanation was not clear. I would like to understand the difference, if any, between LR061253 and SEB500460, and LR061254 and SEB500470.
I think you have answered my question in your other reply and it looks like my logic was OK!
Post #1011545 17th Oct 2023 12:30pm
Albarker55
James - Many thanks. Looks like the part numbers change only to protect the profit margins!!
Post #1011546 17th Oct 2023 12:33pm
geobloke
And probably changes in suppliers etc as well.
Post #1011547 17th Oct 2023 12:37pm
TexasRover
Looking at the calipers I am getting the distinctive impression that the difference between vented and non vented disc is a space piece fitted between the two halves. So really even they are the same no?
Post #1011549 17th Oct 2023 12:51pm
geobloke
Yes they are the same. Just the addition of the spacer and gallery seals.
Post #1011551 17th Oct 2023 12:52pm
Albarker55
Geobloke - Agreed re supplier changing = PN change
Post #1011556 17th Oct 2023 1:19pm
