![]() | Home > Puma (Tdci) > Early Life Oil Changes? |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
Changing oil/ filters can never do any harm.
Best practice seems to be 6k or 6 monthly. Steve ![]() Discovery 3 HSE BMW 330i Coupe |
early on as poss for the first oil change. gets al the swarf out the engine early.
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
totally agree. Plus its so easy to do with everything easily acessible. And with Halfords giving away A1 Magnatec at the moment its a dirt cheap project - less than £45 including filter.
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 ![]() ![]() |
Dont you use Genuine Filters? Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
nope, the Halfords one is made by Coopers and either theirs or Fram or Mahle are as good as OE IMHO and certainly better than Britpart. If I'm wrong in this assumption hopefully someone will tell me sharpish !
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2668 ![]() ![]() ![]() |
I change the oil + filter every 10,000km and after every overlanding trip. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
It's good practice.
I did mine at 1800 miles. Pete |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
Yes, use a good quality filter (from a filter manufacturer), not a cheapo.
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
Would doing this affect your warranty at all, particularly if you use a filter that is obviously not OE (irresepective of whether it's better or not)?
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8204 ![]() ![]() ![]() |
i did the first change at 600miles, then 6k then every 6k there after. Cheers
Dean Watson Member Since: 17 Jul 2011 Location: Derby Posts: 263 ![]() ![]() ![]() |
Thanks for all the replies what do people suggest with axle,gear, and transfer box oils?
Dean |
purely from what I've read about a) the fragility of the Getrag MT82 gearbox and b) alleged quality issues regarding oil spec and quantity on assembly I will be changing my gearbox oil annually. Diffs and transfer box oil will be done every 2 years
No because at service time the old oil filter will be just a filthy black gungy thing that will be thrown away and all car manufacturers know that established companies like Coopers or Fram (as Martin says) produce filters to the highest standards - they just don't add the ridiculously high mark up that OE branded products often have. Once the basic specs are met the biggest variable in every car part designated for OE branding (when motor manufacturers' buyers go shopping around component manufacturers) is always price - every time. See how Toyota recently came a cropper when they bought less than perfect accellerator components because they were cheap. Whether its a good or bad thing today price is king |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2462 ![]() ![]() ![]() |
Somehow related. Changing the oil too often might be not a good idea beacuse of oil volatility. It happens in the first 3000-4000km of use and all lost fractions will go into your engine via PCV, turbo, inlet manifold, causing at the end more soot. Puma 110" SW
