Home > Puma (Tdci) > Fuse box and relays
Gfoster
Fuse box and relays
Hello all,
I have a 2.2 Puma 110.
Does anyone know if there is a fuse/ relay diagram available as having issues withvhazards not working and want to check relay for it but can't find which it is.
Thanks
Post #1010447 7th Oct 2023 8:24pm
macfrank
I only have a LHD diagram with German annotations.
But hazards relay is under the steering wheel, top row left most (on RHD).
So RHD should be:
top row: hazards, wiper, heated front screen timer
bottom row: alarm, window lift + heated seats, heated front screen, head lamps
Post #1010453 7th Oct 2023 8:48pm
Gfoster
Amazing. Thank you will take a look.
Post #1010454 7th Oct 2023 8:50pm
Gfoster
Basically some unsavoury person has tried to steal my 110. The ripped out the indicator wires and tried shorting the alarm.
I now have no hazards or horn, but indicators are working and the alarm/Central looking is still working.
Post #1010455 7th Oct 2023 8:51pm
landy andy
The relay is the same unit for hazards and indicators. So if your indicators are working I doubt it’s the relay
Post #1010456 7th Oct 2023 9:21pm
Gfoster
Thanks Andy. That was my thinking. I'm assuming the hazard switch might be the issue.
Post #1010458 7th Oct 2023 9:28pm
macfrank
Ah those Censored . Sad The indicator trick doesn‘t work anymore for 2.2s
I guess you have checked the fuses anyway?
Post #1010484 8th Oct 2023 7:24am
Martin
Site Admin
If indicators working, it won't be the hazard switch or flasher unit.
Fuse 30 supplies the hazard switch, for hazard light operation.
Fuse 10 supplies the horn.
Both under steering wheel, not under the seat.
Anything else not working?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1010486 8th Oct 2023 7:39am
spudfan
Ireland
This might help.
https://www.lrworkshop.com/wiring-diagram/....2tdci-lhd
https://www.lrworkshop.com/wiring-diagram/....2tdci-lhd 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1010522 8th Oct 2023 2:54pm
