![]() | Home > Puma (Tdci) > Fuse box and relays |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1094 ![]() ![]() ![]() |
I only have a LHD diagram with German annotations.
But hazards relay is under the steering wheel, top row left most (on RHD). So RHD should be: top row: hazards, wiper, heated front screen timer bottom row: alarm, window lift + heated seats, heated front screen, head lamps |
Gfoster Member Since: 07 Oct 2023 Location: Chelmsford Posts: 4 ![]() ![]() |
Amazing. Thank you will take a look.
Basically some unsavoury person has tried to steal my 110. The ripped out the indicator wires and tried shorting the alarm.
I now have no hazards or horn, but indicators are working and the alarm/Central looking is still working. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
The relay is the same unit for hazards and indicators. So if your indicators are working I doubt it’s the relay
Thanks Andy. That was my thinking. I'm assuming the hazard switch might be the issue.
Ah those
![]() ![]() I guess you have checked the fuses anyway? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
If indicators working, it won't be the hazard switch or flasher unit.
Fuse 30 supplies the hazard switch, for hazard light operation. Fuse 10 supplies the horn. Both under steering wheel, not under the seat. Anything else not working? ![]() ![]() |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
This might help.
https://www.lrworkshop.com/wiring-diagram/....2tdci-lhd https://www.lrworkshop.com/wiring-diagram/....2tdci-lhd 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
