![]() | Home > Maintenance & Modifications > Side window guards - internal or external |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
External also makes window cleaning very hard, and also will “test” the durability of the finish.
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 977 ![]() ![]() |
A personal opinion but I recon external guards look a bit poo. And you have to drill the sides so no turning back.
I am fitting internal ones because, as you say, you can hang or strap stuff on and if you decide to sell the car or change configuration at any time it is less involved. |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 260 ![]() ![]() ![]() |
Thanks for the replies.
Reinforces my thoughts to fit internal.. TBH didn’t even think about cleaning the glass! |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2186 ![]() ![]() ![]() |
What is this ‘cleaning’ witchcraft you speak of?
PS Are 90 and 110 sides the same?
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2127 ![]() ![]() ![]() |
Another vote for internal window guards
The other thing in the favour of internal guards is that any lose loads in the vehicle will not hit the window (however is all should be tied down but life happens !) - this is what they are designed to do along with security and the likes .. ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1647 ![]() ![]() |
you'll find internal ones are better but most are external only versions.
outside they rust, inside less so on the last two we built we converted som externals to fit inside and made them removable so we could clean the windows. |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1111 ![]() ![]() ![]() |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 536 ![]() ![]() ![]() |
I quite like the expedition look, especially on a dark colour vehicle, but agree they'd be hard to wash and the powder coating would fall off. They'd definitely be much handier inside to tie things in place.
I always carry a roll of duck tape in case a window breaks, I did have one go out green laning once, how I don't know, it was the one by the back door and I wasn't anywhere near any trees, but tape filled the hole. |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
![]() Click image to enlarge beware of using vents in wet and cold climates, as they cause condensation on the inside of your windows which can be difficult to get rid of. I have vents in my rear windows .... but only in the good summer months, remove them in the winter. Just used for airflow. https://www.ebay.co.uk/itm/115934564771?ha...R6i9wOPhYg GASP !!!! ...... I paid £85 for mine recently. |
Just trying to help ..........
![]() Click image to enlarge new on eBay this evening ........ nothing to do with me......good luck |
Thanks for all the comments and heads up on eBay.
Been out of action last couple of days Internal it is then:- do they get screwed into the body work or just trim. Hate drilling into capping; just doesn't seem right! Now this is solved, next post is about dog guards...again, help welcomed! Kind regards, Robin |
If it is Mantec ones they attach to the trim. I believe MSS ones go under the trim and fix to the sides.
I have instructions for mantec ones. I can take a photo of them and send to you if it helps. |
Thanks, that would be helpful.
