Home > Maintenance & Modifications > Side window guards - internal or external
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Hi,
Looking at pros and cons for guards on rear side windows on a 110 CSW, and any recommendations.
Have looked around at posts and also at MSS, Ore, bison, nakatakatnenger.
Leaning towards internal. My thinking is that internal provides some space to strap things on?
Also, I presume external you will have to drill into the body work, which I prefer to avoid. Is that the case internally?
Obviously, also still want them to open!
Any further points to consider?
As usual, input always appreciated to help in decision process.
May have to post in wanted section..!
Thanks
Rob
Post #1010390 7th Oct 2023 12:21pm
landy andy
External also makes window cleaning very hard, and also will “test” the durability of the finish.
Post #1010396 7th Oct 2023 1:33pm
bodstruck
A personal opinion but I recon external guards look a bit poo. And you have to drill the sides so no turning back.
I am fitting internal ones because, as you say, you can hang or strap stuff on and if you decide to sell the car or change configuration at any time it is less involved.
Post #1010415 7th Oct 2023 4:28pm
DC101
Thanks for the replies.
Reinforces my thoughts to fit internal..
TBH didn’t even think about cleaning the glass!
Post #1010420 7th Oct 2023 5:16pm
Screbble
What is this ‘cleaning’ witchcraft you speak of?
Post #1010422 7th Oct 2023 5:22pm
DC101
PS Are 90 and 110 sides the same?
Post #1010424 7th Oct 2023 5:29pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Another vote for internal window guards
The other thing in the favour of internal guards is that any lose loads in the vehicle will not hit the window (however is all should be tied down but life happens !) - this is what they are designed to do along with security and the likes ..
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #1010436 7th Oct 2023 6:39pm
Mdm
you'll find internal ones are better but most are external only versions.
outside they rust, inside less so
on the last two we built we converted som externals to fit inside and made them removable so we could clean the windows.
Post #1010449 7th Oct 2023 8:31pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Rolling with laughter my thoughts exactly
Post #1010451 7th Oct 2023 8:40pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I quite like the expedition look, especially on a dark colour vehicle, but agree they'd be hard to wash and the powder coating would fall off. They'd definitely be much handier inside to tie things in place.
I always carry a roll of duck tape in case a window breaks, I did have one go out green laning once, how I don't know, it was the one by the back door and I wasn't anywhere near any trees, but tape filled the hole.
Post #1010487 8th Oct 2023 7:41am
LR Nuts
beware of using vents in wet and cold climates, as they cause condensation on the inside of your windows which can be difficult to get rid of.
I have vents in my rear windows .... but only in the good summer months, remove them in the winter.
Just used for airflow.
https://www.ebay.co.uk/itm/115934564771?ha...R6i9wOPhYg
GASP !!!! ...... I paid £85 for mine recently.
Post #1010488 8th Oct 2023 7:44am
LR Nuts
Just trying to help ..........
new on eBay this evening ........ nothing to do with me......good luck
Post #1010558 8th Oct 2023 7:00pm
DC101
Thanks for all the comments and heads up on eBay.
Been out of action last couple of days
Internal it is then:- do they get screwed into the body work or just trim.
Hate drilling into capping; just doesn't seem right!
Now this is solved, next post is about dog guards...again, help welcomed!
Kind regards,
Robin
Post #1010828 11th Oct 2023 8:10am
bodstruck
If it is Mantec ones they attach to the trim. I believe MSS ones go under the trim and fix to the sides.
I have instructions for mantec ones. I can take a photo of them and send to you if it helps.
Post #1010838 11th Oct 2023 9:01am
DC101
Thanks, that would be helpful.
Post #1010862 11th Oct 2023 11:13am
