Home > Td5 > TD5 seriously hot exhaust gasses
alexatnd
Hi,
Recently had cause to replace the head gasket on my 1999 10p TD5 as had a serious coolant leak that i couldnt track down.
To say the head gaske was s*****d would be an understatement!
As part of the gasket change I used 3 cable ties to ensure the timing chain stayed where it was on the top sprocket.
The change went fine and was pleased when she started 1st time. I now definiotely dont have any coolant leaks. However ....
The exhaust gasses are definitely far far hotter than they were before or comppare to my other td5. Also after driving for 5 or 10 moins defintiely get a burning oil smell as if some landed on exhaust and is being burnt off.
When i fitted the upper sprocket had no trouble fitting the 3 bolts, they all went in easily, but I am now wondering if the timing chain may have sliped along a tooth when i fitted it back on.
Would it be possible to fit the sprocket 1 tooth out even when its all cabletied to the chain so it cant move at that end?
Also got an occasional missfire and unburnt diesel at the exhaust for a while when i start up.
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost
Effie - 2004 110 TD5 County
Post #1009153 27th Sep 2023 5:17pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Are you able to measure your EGT? Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1009164 27th Sep 2023 6:01pm
NickMc
Split fuel cooler? Oil cooler in good shape?
Post #1009181 27th Sep 2023 7:25pm
geobloke
My question too.
Oil in the exhaust down-pipe?!
Post #1009182 27th Sep 2023 7:29pm
