Home > Modifications & Maintenance (L663) > Which oil extraction pump?
Co1
Did a bit of a search and surprisingly couldn’t find anything. For those that change their own oil, which extraction pump do you use?
Post #1008608 23rd Sep 2023 6:52pm
lightning
These are as good as any, and it's the one l've used.
lt comes with various sizes of tube and one of them fits down the dipstick hole of the Defender. However once in place it's not long enough to reach the pump! But you can join two tubes together using one of the rubber adapters and than it's fine, the pump can be placed on the ground next to the vehicle.
The Defender holds around 8.5 litres of oil so the pump reservoir is large enough, just.
https://www.ebay.co.uk/itm/314813645724?mk...media=COPY
Post #1008618 23rd Sep 2023 9:13pm
Co1
Cheers. Any idea on oil volume? There seems to be surprisingly little info on here using the search button.
Post #1009185 27th Sep 2023 8:41pm
Co1
I’m an idiot, just read your post again!!
Post #1009188 27th Sep 2023 8:49pm
