Home > Modifications & Maintenance (L663) > Which oil extraction pump? |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2840 |
These are as good as any, and it's the one l've used.
lt comes with various sizes of tube and one of them fits down the dipstick hole of the Defender. However once in place it's not long enough to reach the pump! But you can join two tubes together using one of the rubber adapters and than it's fine, the pump can be placed on the ground next to the vehicle. The Defender holds around 8.5 litres of oil so the pump reservoir is large enough, just. https://www.ebay.co.uk/itm/314813645724?mk...media=COPY Last edited by lightning on 29th Sep 2023 11:22am. Edited 1 time in total |
23rd Sep 2023 8:13pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3679 |
Cheers. Any idea on oil volume? There seems to be surprisingly little info on here using the search button.
27th Sep 2023 7:41pm |
I’m an idiot, just read your post again!!
27th Sep 2023 7:49pm |
