Home > General & Technical (L663) > IID gap pro problem |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 |
Not heard of that one before but walk away lock and open doesn't work on all MY2022's You could ask in the L663 section of the forum where new Defender owners are more likely to see it and in particular the GAP thread https://www.defender2.net/forum/topic85281.html
Edited to add, I've asked Martin to move the thread to the correct section Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
19th Sep 2023 11:49pm |
Defenderl663ok Member Since: 16 Sep 2023 Location: Sheffield Posts: 3 |
Thank you so much for the advice. Much appreciated
20th Sep 2023 4:32am |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 270 |
Walk away locking only works on cars that don’t have a locking fuel flap, this is due to a change in the BCM. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
20th Sep 2023 11:30am |
Hi.
I don't have the locking fuel cap. I think the ghost immobiliser must be playing a part in the problem. When activated it disables my engine from starting and the touch unlock and lock on the door. As soon has I disable the feature on the screen everything is working fine. Thank you. |
20th Sep 2023 11:35am |
