Home > General & Technical (L663) > IID gap pro problem
Defenderl663ok
IID gap pro problem
Hi everyone.
I have just enabled walk away look and open. something very strange happened, when both was activated my l633 my22 250 car would not start, i do have ghost fitted, don't know if this is the problem. when i deactivate the open facility on my privi the engines starts. will email pat and see if he has had this before.. has anyone else had the problem
Thanks in advance
Post #1008207 19th Sep 2023 9:22pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Not heard of that one before but walk away lock and open doesn't work on all MY2022's You could ask in the L663 section of the forum where new Defender owners are more likely to see it and in particular the GAP thread https://www.defender2.net/forum/topic85281.html Thumbs Up
Edited to add, I've asked Martin to move the thread to the correct section Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1008221 20th Sep 2023 12:49am
Defenderl663ok
Thank you so much for the advice. Much appreciated
Post #1008224 20th Sep 2023 5:32am
whiterdesign
Walk away locking only works on cars that don’t have a locking fuel flap, this is due to a change in the BCM. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #1008259 20th Sep 2023 12:30pm
Defenderl663ok
Hi.
I don't have the locking fuel cap. I think the ghost immobiliser must be playing a part in the problem. When activated it disables my engine from starting and the touch unlock and lock on the door. As soon has I disable the feature on the screen everything is working fine.
Thank you.
Post #1008260 20th Sep 2023 12:35pm
