Home > My Defender > My 110 XS USW "Winnie"
Page 2 of 3 <123>
geobloke
Super bit of DIY spray painting and maintenance Thumbs Up I remember when my steering damper was yellow... Rolling Eyes
Post #1009795 2nd Oct 2023 7:53pm
Ambo_Chris
United Kingdom 2013 Defender 110 Puma 2.2 USW Baltic Blue
L110CDL wrote:
Nice bit of work carried out there, have you noticed the difference with the new on there now ?
It does feel better, waiting for a dry day to do the rear track rod bar as ran out of time so that should help. 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
2000 Beige Discovery 2 Td5 GS (Long gone)
1994 Red (various) 90 300tdi CSW (Long gone)
Post #1009854 3rd Oct 2023 7:39am
L110CDL
That is good news and it should be a bit better again once you have done the rear one Thumbs Up Clayton.
Keeper.
Post #1010197 5th Oct 2023 8:25pm
Ambo_Chris
Had a delivery from Paddocks…
Post #1012016 21st Oct 2023 2:37pm
Ambo_Chris
I think the wolfs look much better than the tired SVX alloys!
Post #1012017 21st Oct 2023 2:38pm
seriesonenut
A good look. I went black in the end for mine.
wolf2black by Richard Holmes, on Flickr 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #1012037 21st Oct 2023 5:08pm
Screbble
That does look nice 👍
Post #1012083 22nd Oct 2023 10:27am
L110CDL
They do look nice but the white lettering spoils it ( imo ) Thumbs Up Clayton.
Keeper.
Post #1012337 23rd Oct 2023 8:07pm
Ambo_Chris
Replacement Aircon Condenser and Fan
So I've managed to fit in a few jobs over the new year, working through the list from the garage.
First up was the leaking aircon condenser.
I got one of the larger non-genuine replacement condensers from eBay (seller was Premier Supply) for £125 delivered.
https://www.ebay.co.uk/str/premiersupplyuk...media=COPY
and a 350mm Spal Fan, (VA08-AP10/C-23S, 12v Push) for £85. All in, a very easy job. Ony took about an hour. I made some T shaped fixings to fit the fan using some stainless bolts copying the SPAL fitting kit, but for a fraction of the price.
I'll get the system regassed when it goes in to have the rear diff replaced.
Post #1021313 15th Jan 2024 8:43pm
Ambo_Chris
Front Door Top Repair
Next was a repair to the top of the driver's door where it has cracked by the door lock mechanism. The loose trim and rattling window was starting to become a right pain!
I cut out the top piece, then tidied up the edges and pained with primer. The new piece fitted fine with no trimming and as I don't have access to a welder, I riveted it in place after a coat of paint. unfortunately I've run out of the body colour I used for the hinges, so its jut primer for now.
Post #1021315 15th Jan 2024 8:53pm
Ambo_Chris
Exmoor Trim Premium Upgrade ReTrim Kit
The Driver's seat back bolster had completely collapsed, making even the shortest drive pretty uncomfy so I took advantage of Exmoor trims 10% off deal before Christmas and got a two seat retrim kit with some new seat heaters. Took about 3 hours with the base being the most fiddly!
Just the passenger one to do now!
Post #1021318 15th Jan 2024 9:03pm
L110CDL
Thank you for the update with the pic's and a few more jobs ticked off the list Very Happy Clayton.
Keeper.
Post #1021333 15th Jan 2024 9:42pm
Ambo_Chris
Passenger side completed now too. Really smartens up the interior!
Post #1021416 16th Jan 2024 5:34pm
Ambo_Chris
A couple of small electrical jobs today; fitted an extra USB socket by the passenger grab handle as the LR one always seems to be in the way. I used one of MUD UKs piggyback looms for the moment as I don't plan on using the original one. I also fitted a Vellerman 12v battery indicator light in the vacant button blank on the dash so I can keep an eye on the batttery charging. link here: http://www.velleman.co.uk/contents/en-uk/p114.html. it comes on with the ignition, then gives a slow flash whilst charging, then indicates red if battery low or overcharging. I saw someone else on here had done this mod, can't remember who to credit!
Post #1026360 29th Feb 2024 1:43pm
Ambo_Chris
Water Ingress
In an effort to try and stop the water ingress, the stars aligned and I have a few dry days off work. I replaced the rear body capping to side panel seals with new ones from YRM as it was leaking on one side through this joint:
Whilst I was at it, I replaced the gaskets and bolts on the windscreen hinge blocks too. 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
Post #1037036 10th Jun 2024 5:03pm
Page 2 of 3 <123>
