Home > My Defender > My 110 XS USW "Winnie" |
Super bit of DIY spray painting and maintenance I remember when my steering damper was yellow...
2nd Oct 2023 6:53pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10810 |
That is good news and it should be a bit better again once you have done the rear one 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
5th Oct 2023 7:25pm |
Ambo_Chris Member Since: 01 Dec 2021 Location: South West Posts: 31 |
Had a delivery from Paddocks…
Click image to enlarge 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
21st Oct 2023 1:37pm |
I think the wolfs look much better than the tired SVX alloys!
Click image to enlarge Click image to enlarge 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
21st Oct 2023 1:38pm |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1225 |
A good look. I went black in the end for mine.
Click image to enlargewolf2black by Richard Holmes, on Flickr 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
21st Oct 2023 4:08pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2108 |
That does look nice 👍 |
22nd Oct 2023 9:27am |
They do look nice but the white lettering spoils it ( imo ) 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
23rd Oct 2023 7:07pm |
So I've managed to fit in a few jobs over the new year, working through the list from the garage.
First up was the leaking aircon condenser. I got one of the larger non-genuine replacement condensers from eBay (seller was Premier Supply) for £125 delivered. https://www.ebay.co.uk/str/premiersupplyuk...media=COPY and a 350mm Spal Fan, (VA08-AP10/C-23S, 12v Push) for £85. All in, a very easy job. Ony took about an hour. I made some T shaped fixings to fit the fan using some stainless bolts copying the SPAL fitting kit, but for a fraction of the price. I'll get the system regassed when it goes in to have the rear diff replaced. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
15th Jan 2024 7:43pm |
Next was a repair to the top of the driver's door where it has cracked by the door lock mechanism. The loose trim and rattling window was starting to become a right pain!
Click image to enlarge I cut out the top piece, then tidied up the edges and pained with primer. The new piece fitted fine with no trimming and as I don't have access to a welder, I riveted it in place after a coat of paint. unfortunately I've run out of the body colour I used for the hinges, so its jut primer for now. Click image to enlarge Click image to enlarge 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
15th Jan 2024 7:53pm |
The Driver's seat back bolster had completely collapsed, making even the shortest drive pretty uncomfy so I took advantage of Exmoor trims 10% off deal before Christmas and got a two seat retrim kit with some new seat heaters. Took about 3 hours with the base being the most fiddly!
Just the passenger one to do now! Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
15th Jan 2024 8:03pm |
Thank you for the update with the pic's and a few more jobs ticked off the list 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
15th Jan 2024 8:42pm |
Passenger side completed now too. Really smartens up the interior!
16th Jan 2024 4:34pm |
A couple of small electrical jobs today; fitted an extra USB socket by the passenger grab handle as the LR one always seems to be in the way. I used one of MUD UKs piggyback looms for the moment as I don't plan on using the original one. I also fitted a Vellerman 12v battery indicator light in the vacant button blank on the dash so I can keep an eye on the batttery charging. link here: http://www.velleman.co.uk/contents/en-uk/p114.html. it comes on with the ignition, then gives a slow flash whilst charging, then indicates red if battery low or overcharging. I saw someone else on here had done this mod, can't remember who to credit!
29th Feb 2024 12:43pm |
In an effort to try and stop the water ingress, the stars aligned and I have a few dry days off work. I replaced the rear body capping to side panel seals with new ones from YRM as it was leaking on one side through this joint:
Click image to enlarge Click image to enlarge Click image to enlarge Whilst I was at it, I replaced the gaskets and bolts on the windscreen hinge blocks too. 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
10th Jun 2024 4:03pm |
