Home > Maintenance & Modifications > Front seat box centre panel clips
excossack
What sort of clips/fasteners are fitted to hold the centre front seat box panel in place (the one over the transfer case) I thought standard flat clips that a screw passes through would do the job, but there is a lip on the opening which stops these going on. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1007334 12th Sep 2023 7:58am
Dinnu
See #6
https://www.lrworkshop.com/diagrams/land-r...gs_52756#6
Thats what my 1988 has. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1007339 12th Sep 2023 8:27am
rallysteve
Yup, 4-off metal push in clips as above.
Post #1007343 12th Sep 2023 8:52am
excossack
Cheers both. These clips push into the round holes in the main seat base section? i.e not the top lid (item 1) 1999 Defender TD5 110
Regards
John M0VAZ
Post #1007370 12th Sep 2023 12:52pm
Dinnu
Yes, they push into the holes in the seatbox. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1007371 12th Sep 2023 1:22pm
geobloke
It would be worth getting some 2mm closed cell foam strip to replace the stuff on the lid. They usually get very flat and let cold/heat in/out.
Post #1007373 12th Sep 2023 2:21pm
TexasRover
Quite an elegant design too! The screw locks the clip firmly inside the square hole. Also not Plastic, Plastic is never the most elegant solution given time..
Post #1007374 12th Sep 2023 2:25pm
Dinnu
The hole in the seatbox is actually not a round hole, but looked like there’s a superimposed square hole. Unless the latter was created by vibration over the many years the clips were installed. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1007378 12th Sep 2023 3:27pm
excossack
I have added foam strip around the lid already Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #1007385 12th Sep 2023 4:13pm
excossack
I will double check but mine do look round. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1007386 12th Sep 2023 4:14pm
geobloke
Thumbs Up Thumbs Up
Post #1007388 12th Sep 2023 4:31pm
excossack
Also adding some 5mm foam between the metal plate and the base of the cubby, for two reasons
1. I discovered an annoying squeak as two bolts for the cubby are missing(my bad) which was when I noticed a lack of fixings apart from the two at front by the ECU diagnostic socket/mounting bracket
2. To add some more noise deadening. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1007418 12th Sep 2023 7:46pm
