Home > Maintenance & Modifications > Front seat box centre panel clips |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
See #6
https://www.lrworkshop.com/diagrams/land-r...gs_52756#6 Thats what my 1988 has. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
12th Sep 2023 8:27am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
Yup, 4-off metal push in clips as above.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
12th Sep 2023 8:52am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5843 |
Cheers both. These clips push into the round holes in the main seat base section? i.e not the top lid (item 1) 1999 Defender TD5 110
12th Sep 2023 12:52pm |
Yes, they push into the holes in the seatbox. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
12th Sep 2023 1:22pm |
It would be worth getting some 2mm closed cell foam strip to replace the stuff on the lid. They usually get very flat and let cold/heat in/out.
12th Sep 2023 2:21pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1051 |
Quite an elegant design too! The screw locks the clip firmly inside the square hole. Also not Plastic, Plastic is never the most elegant solution given time.. |
12th Sep 2023 2:25pm |
The hole in the seatbox is actually not a round hole, but looked like there’s a superimposed square hole. Unless the latter was created by vibration over the many years the clips were installed. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
12th Sep 2023 3:27pm |
I have added foam strip around the lid already 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
12th Sep 2023 4:13pm |
I will double check but mine do look round. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
12th Sep 2023 4:14pm |
12th Sep 2023 4:31pm |
Also adding some 5mm foam between the metal plate and the base of the cubby, for two reasons
1. I discovered an annoying squeak as two bolts for the cubby are missing(my bad) which was when I noticed a lack of fixings apart from the two at front by the ECU diagnostic socket/mounting bracket 2. To add some more noise deadening. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
12th Sep 2023 7:46pm |
