Home > Puma (Tdci) > Tow bar question
tristanpowter
Tow bar question
Hi all quick question on the standard Land Rover tow bar, see below pic, am I able to adapt this to a drop plate (removable pin) system or would I need to buy a whole new assembly? Be great if someone could post a link to parts I need if so.
Suspicions are I need the larger adjustable hitch as the whole bracket looks different but would save if I could just remove tow ball and attach the sliding bracket.
Thanks!
Post #1007325 12th Sep 2023 6:57am
geobloke
Crikey, back in the old days you'd just bolt the adjustable ladder to the Series 3 or Defender tow plate (as you suggest) and off you go, but I suspect that may be frowned upon these days.
Post #1007328 12th Sep 2023 7:41am
Dinnu
I had the same problem that I needed different tow ball height setup - but since it was occasional, I simply relocated the tow ball on one of the 3 heights available on the tow plate.
However I wonder if something like in this link could be a solution. Unfortunately I am not near to my Defender to measure the hole spacing and if they match with those on the tow plate.
https://www.ebay.de/itm/373866563048?_trkp...%3A4429486 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1007329 12th Sep 2023 7:44am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Bolt the drop plate to your existing setup.
I'd recommend the 2 pin type over the 1 pin style to reduce rattling, as there's enough of that going on. I even went the extra mile and bought a 2nd drop plate which I've fitted the bike rack mount to 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #1007336 12th Sep 2023 8:01am
camelman
Can your Nato hitch rotate when at that height with the 50mm ball in that position?
Post #1007337 12th Sep 2023 8:17am
Rosco
Yes, but the securing tab is tight on the ball coupler so I tend to fit it upside down to make it an easier fit. Securing tab then obviously locked open.
It will fit further up, but the spare wheel postion then fouls the hitch from opening 2007 - Stornoway Grey 90 XS SW - Gone
Post #1007360 12th Sep 2023 11:21am
camelman
I went for a removable 2 inch receiver in the end with a number of attachments, 50mm ball, Nato hitch, pin or step.
Post #1007362 12th Sep 2023 11:30am
tristanpowter
Great thanks , my understanding is that the drop plate you have only requires 2 bolts to existing plate (not 4) is that correct?
Post #1007405 12th Sep 2023 6:19pm
JOW240725
This page should probably help with all you need.
https://www.lrworkshop.com/diagrams/land-r...mbly_44765 James
Instagram @suffolk_rovers
Post #1007409 12th Sep 2023 6:59pm
It's not possible to determine the year of your vehicle from the photo but you might want to bear in mind that if it is recent enough to require a type approved towbar (i.e., first registered on or after 31/10/2012) simply bolting a ladder onto your current drop plate is unlikely to be legal. A safer option (from the compliance standpoint) would be to fit the proper adjustable set-up which is fully type approved.
Edit: I note from your grill thread that it's a 60 plate so old enough as an N1 vehicle NOT to need a TA towbar.
Post #1007412 12th Sep 2023 7:18pm
tristanpowter
Thanks all for the above info ! Yes makes sense
Post #1007414 12th Sep 2023 7:35pm
Dinnu
I would not trust it on 2 bolts. Reason is that if you adjust the height such that you are much higher or lower than the attaching bolts, the forces are amplified by the ratio of the distances, and always greater than originally designed. Granted that an M16 bolt can handle quite a load, but have seen them fail spectacularly when abuse. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1007444 13th Sep 2023 4:02am
X4SKP
Hello tristanpowter
As blackwolf says not requiring a type approved set up gives you more ‘room to manoeuvre’
in considering what you could do.
The Dixon Bate kit together with various pdf plans are available on-line so it’s possible to work out
what will you’ll get, working back from what you want (I hope that makes sense Shocked )
I needed a tow ball centre height of around 345mm, and have achieved this off the back of my 90
and my wife’s 110 (MY 2010 / 2011 respectively), both can accept a NATO hitch when required….
(X-MOD Trailer).
As commented on, good to aim for the best set up possible, particularly (IMO) with bracing metalwork
back to the chassis, if you have a ‘low’ end result assembly…
Here’s generally the approach I took…
https://www.defender2.net/forum/topic83242-15.html
(scroll well down…)
Good luck… Thumbs Up SKIP
Post #1007478 13th Sep 2023 11:07am
