Home > For Sale & Wanted > [Swap] +2 Brand new Fox shocks for standard length.
itsdashy
United Kingdom 2012 Defender 90 Puma 2.2 PU Orkney Grey
It's a long shot but as above really. I would like to swap my boxed, never used +2" shocks for a set of new or lightly used standard length ones.
Project creep has set in and I don't want or need the lift anymore.
Post #1007249 11th Sep 2023 4:38pm
itsdashy
Bump?
Post #1042214 8th Aug 2024 10:51am
Chicken Drumstick
Just an fyi. A longer shock doesn’t have to be for a lift. You can run longer shocks at stock ride height. The only risk is the spring dislocating at full droop. But this could happen with a lift too depending on how it was lifted.
You can easily retain the springs or add dislocation cones. And chances are you wouldn’t be getting any extra flex on the front axle anyway. The shock length isn’t typically the first limitation to solve in the front.
Post #1042235 8th Aug 2024 2:18pm
itsdashy
Aaah brilliant . I'll chuck them on then and give it a go. Might put some cones on for extra points. Thanks for the excellent info. [/quote]
Post #1042242 8th Aug 2024 2:56pm
M94PUMA
Doh! Was going to suggest different shock mounts but think they only sell 2” lower mounts not taller! Then your +2” shocks would run at standard height.
Post #1042246 8th Aug 2024 3:17pm
