Home > For Sale & Wanted > [Swap] +2 Brand new Fox shocks for standard length. |
itsdashy Member Since: 20 May 2021 Location: Reading Posts: 72 |
Bump?
8th Aug 2024 10:51am |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 749 |
Just an fyi. A longer shock doesn’t have to be for a lift. You can run longer shocks at stock ride height. The only risk is the spring dislocating at full droop. But this could happen with a lift too depending on how it was lifted.
You can easily retain the springs or add dislocation cones. And chances are you wouldn’t be getting any extra flex on the front axle anyway. The shock length isn’t typically the first limitation to solve in the front. |
8th Aug 2024 2:18pm |
Aaah brilliant . I'll chuck them on then and give it a go. Might put some cones on for extra points. Thanks for the excellent info. [/quote]
8th Aug 2024 2:56pm |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 126 |
Doh! Was going to suggest different shock mounts but think they only sell 2” lower mounts not taller! Then your +2” shocks would run at standard height.
8th Aug 2024 3:17pm |
