![]() | Home > General & Technical (L663) > What do you use the diamond button for? |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2980 ![]() ![]() |
Stop/start disable
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1235 ![]() ![]() |
sorry to say .....
https://www.ownerinfo.landrover.com/docume...6/G3346810 ![]() Click image to enlarge The diamond button on the steering wheel is a 'Customisable' function (Driver selected, through the PiVi screen.) https://www.ownerinfo.landrover.com/docume...5/G2390263 |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 111 ![]() ![]() |
That was one I was thinking about until I set my stop start disable to remember it’s last setting. |
So you’re saying the diamond button can’t be set to auto stop start disable? |
this lists the only functions under 'Diamond steering wheel' control. edit. https://www.ownerinfo.landrover.com/docume...2/G2390290 |
I just sat down in my defender and, while I didn’t find auto stop start, the list is a whole lot longer than what’s in the manual. Mostly in the app launch section. I found a few I might try out.
Mrburt Member Since: 04 Jan 2023 Location: Shropshire Posts: 33 ![]() ![]() |
Short press - Cameras
Long press - Apple CarPlay |
I’m new to this, so I don’t know when they added app launch. I also went with cameras for short press. Currently long press is dynamic. I’ll prolly change that, as I don’t see using dynamic much. I’m surprised they didn’t make that button much more flexible. |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 163 ![]() ![]() |
Short press - mute
Long press - cancel Navigation Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
MickD Member Since: 28 Jul 2023 Location: New England Posts: 28 ![]() ![]() |
Short - Cameras
Long - Stealth Mode |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3701 ![]() ![]() ![]() |
What is Stealth mode?
mbso Member Since: 01 Sep 2021 Location: Genoa Posts: 101 ![]() ![]() |
Ciao, Hi all
Short - Mute Long - Cancel Navigation ![]() I'm curious ... What is Stealth mode? DISCOVERY 4 2013 VOLVO XC90 2017 MY23.5 110 D250 SE in Santorini Black Last edited by mbso on 4th Sep 2023 8:57am. Edited 1 time in total |
Yes you can set it to disable stop/start. l know there's a button to do that next to the shift lever but l find the steering wheel one more convenient.
l also set it to mute the audio. |
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 523 ![]() |
I use it to switch to 360 camera - I tend to end up in tight spaces a lot driving in the city and find it useful to be able to switch immediately whilst trying to negotiate a tricky spot.
and Long push = change source between DAB and Spotify. If the radio is crap I frequently move to spotify. |
