Home > Maintenance & Modifications > Rear arch flares for 110 pickup
Bailey123
Hello all,
I have a defender 110 high capacity pickup, 2015. The vehicle has flares on the front arch, however none on the rear wheels. When Iv looked there’s no obvious way of fitting flares, and can’t seem to find any options online that would fit. Any advice on what to do?
If it’s going to be a big job to fit then its not the end of the world if they don’t get fit, just thought it’d look more symmetrical and better with them on the rear also.
Post #1006349 3rd Sep 2023 3:14pm
bankz5152
Never had them fitted. Only real options are the bolt on type wide arches
Post #1006351 3rd Sep 2023 3:26pm
Bailey123
I was hoping to avoid any bolting, the area you would bolt to is in a hollow between the arch and the back of the pickup body. So I imagine it would be a nightmare bolting anything on, and not been able to get to the back of the bolt. (Hope that make sense)
Post #1006353 3rd Sep 2023 3:41pm
bankz5152
You would use rivnuts.
Post #1006363 3rd Sep 2023 4:42pm
Bailey123
Makes sense. Thanks a lot for your advice, will source rear arches and rivnut them on.
Post #1006368 3rd Sep 2023 5:05pm
bankz5152
I would leave it as is tbh, they look good and youll find the rear wider than the front!
Post #1006374 3rd Sep 2023 5:18pm
landy andy
You could just glue then on with pu sealer like tiger seal
That’s what I did when a Sankey.
Post #1006385 3rd Sep 2023 6:49pm
Oldowner
I had a Hicap cherrypicker which had wheel arches as it had wider wheels than standard so required them to be legal. They were rear ones riveted on with penny washers. Looked stupid though as they stuck out too far in comparison with the front.
Post #1006388 3rd Sep 2023 8:25pm
