![]() | Home > Maintenance & Modifications > Rear arch flares for 110 pickup |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Never had them fitted. Only real options are the bolt on type wide arches Instagram @defender_ventures
Empire Tuning - Agent |
Bailey123 Member Since: 03 Sep 2023 Location: Scarborough Posts: 3 ![]() ![]() |
I was hoping to avoid any bolting, the area you would bolt to is in a hollow between the arch and the back of the pickup body. So I imagine it would be a nightmare bolting anything on, and not been able to get to the back of the bolt. (Hope that make sense)
You would use rivnuts. Instagram @defender_ventures
Makes sense. Thanks a lot for your advice, will source rear arches and rivnut them on.
Cheers |
I would leave it as is tbh, they look good and youll find the rear wider than the front! Instagram @defender_ventures
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
You could just glue then on with pu sealer like tiger seal
That’s what I did when a Sankey. ![]() Click image to enlarge |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 639 ![]() ![]() ![]() |
I had a Hicap cherrypicker which had wheel arches as it had wider wheels than standard so required them to be legal. They were rear ones riveted on with penny washers. Looked stupid though as they stuck out too far in comparison with the front.
