Home > General & Technical (L663) > Clutch gone - 8k miles
JS
United Kingdom 2013 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi all
I think my clutch has gone Big Cry
I bought a 62-plate SW XS 1 year ago with just under 5k miles on the clock, I've just got it up to 8k cruising around the lake district but the clutch went spongey and then completely went this evening. Can't get it into gear at all so pushed it into a car parking space in Keswick.
Am I doomed (new clutch) or could it be something much simpler considering the mileage?
Any reassurance/ advice is much appreciated!!
Post #1005951 30th Aug 2023 7:19pm
DSC-off
Hi, welcome to the forum. You've posted this in the New Defender (L663) section, they'll be jealous they've not got a clutch Whistle
It could be a hydraulic problem, check the brake fluid reservoir level, topping it up will get you moving again.
It may be a leak in the master cylinder or slave cylinder if there is fluid loss. Probably best to change both for good quality replacements, due to very little use over a long time.
Good luck getting it fixed. Thumbs Up
Post #1005953 30th Aug 2023 7:35pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi
It sounds as if the seal has gone in the clutch master cylinder.
Have you checked the fluid reservoir?
Jim
Post #1005954 30th Aug 2023 7:35pm
J77
A clutch? What is this thing you speak of?
Laughing 24MY 90 D250 HSE, Tasman Blue
Post #1005959 30th Aug 2023 8:10pm
Moo
Ukraine
I got worried I'd missed the manual box option Laughing Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1005960 30th Aug 2023 8:16pm
