Home > General & Technical (L663) > Clutch gone - 8k miles |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1442 |
Hi, welcome to the forum. You've posted this in the New Defender (L663) section, they'll be jealous they've not got a clutch
It could be a hydraulic problem, check the brake fluid reservoir level, topping it up will get you moving again. It may be a leak in the master cylinder or slave cylinder if there is fluid loss. Probably best to change both for good quality replacements, due to very little use over a long time. Good luck getting it fixed. |
30th Aug 2023 7:35pm |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 847 |
Hi
It sounds as if the seal has gone in the clutch master cylinder. Have you checked the fluid reservoir? Jim |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 |
A clutch? What is this thing you speak of?
24MY 90 D250 HSE, Tasman Blue |
30th Aug 2023 8:10pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1437 |
I got worried I'd missed the manual box option Eiger Grey MY23 D250 SE with bits. Known as Noddy.
30th Aug 2023 8:16pm |
