![]() | Home > Technical > Noise on and off power |
Big Red the Yorkshire Defender Member Since: 25 Aug 2023 Location: Darlington Posts: 8 ![]() ![]() ![]() |
Hi, please bare with me as I am very new to this site. I have a PUMA 110, and at motorway speeds I get a noise when going on and off the, sound's like it is coming from below the driver's / passengers seats!
Does anyone have any ideas? Thx |
on and off the power
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 ![]() ![]() |
What sort of noise?
If it is a knocking, tapping type sound it could be you have a two pin front diff, which would soon like to leave you. This can be checked via the front diff fill hole and some torch action. 👍🏻 Last edited by landy andy on 26th Aug 2023 9:58am. Edited 1 time in total |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2654 ![]() ![]() ![]() |
Do you have a local garage that can put it up on a lift so that it could be ‘driven’ and then the area can be better pin pointed instead of buying parts and chasing noises.
Might be better to do than speculating Good luck. |
Thanks all, plenty to think about
