  • You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Technical > Noise on and off power
Big Red the Yorkshire Defender
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Rimini Red
Hi, please bare with me as I am very new to this site. I have a PUMA 110, and at motorway speeds I get a noise when going on and off the, sound's like it is coming from below the driver's / passengers seats!
Does anyone have any ideas?
Thx
Post #1005409 25th Aug 2023 12:40pm
on and off the power
Post #1005415 25th Aug 2023 2:45pm
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
could be worn prop UJ's, transfer case bearings, gearbox bearings, wheel bearings?....few things it could be.
one good place to start is the props and then work back throguh the transmission if it is a whine type noise on or off power. Defender 130 HCPU TD5
Post #1005419 25th Aug 2023 3:32pm
landy andy
What sort of noise?
If it is a knocking, tapping type sound it could be you have a two pin front diff, which would soon like to leave you.
This can be checked via the front diff fill hole and some torch action. 👍🏻
Post #1005463 26th Aug 2023 5:51am
markb110
Do you have a local garage that can put it up on a lift so that it could be ‘driven’ and then the area can be better pin pointed instead of buying parts and chasing noises.
Might be better to do than speculating
Good luck.
Post #1005473 26th Aug 2023 9:29am
Thanks all, plenty to think about
Post #1005569 27th Aug 2023 2:58pm
