Home > Technical > Excess play in steering
Page 2 of 2 <12
excossack
two pairs of mole grips each side of the UJ and see if you have any play? or remove it completely for a better look?
If you can get Debbie M to assist good luck. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1016611 28th Nov 2023 10:54am
L110CDL
I have just had this, it started at the beginning of this week and i managed to get to my indy today so he could have a look, it turned out to be the new drop arm link, which i had to have for the mot, it was slightly lose, wobbled a bit, due to the paint wearing off, he said that they can do this, so he tightened it up and now it's all good Very Happy Clayton.
Keeper.
Post #1016925 30th Nov 2023 11:15pm
Grenadier
Where exactly did it become loose Clayton? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #1017008 1st Dec 2023 2:17pm
geobloke
Please oh please Clayton tell me you were "loose about his hoose" Rolling with laughter
https://youtu.be/qqCZe3WA-zE?si=1UziofpHTBIGbKsG When adverts were awesome Thumbs Up
I'll get me coat now... Rolling Eyes
Post #1017012 1st Dec 2023 2:30pm
L110CDL
Sadly i remember that Rolling Eyes Clayton.
Keeper.
Post #1017077 1st Dec 2023 9:48pm
L110CDL
Here you go Grenadier, hope this helps you
Thumbs Up Clayton.
Keeper.
Post #1017079 1st Dec 2023 9:51pm
Rescue01
I will need to keep a eye on that as I just replaced my drop arm recently Thumbs Up
Post #1017093 1st Dec 2023 11:44pm
Pughey14
Im just looking for some advice on the same subject.
I have a 2009 tdci done around 72,000 which has play in the steering.
I have replace the following components over the past two years
Radius arm bushes, drop arm ball joint, steering lower uj, track rod end ball joints, steering damper, wheel bearing.
I adjusted the steering box and have had the tracking done. None of theses seemed to make any improvement.
I took it to a specialist landrover mechanics who couldn’t seem to find any problem apart from a loose wheel bearing which when fixed seemed to make no improvement.
The only thing I believe to still be the culprit would be the steering box itself…. Should this need replacing at such mileage?
Post #1037617 16th Jun 2024 5:35pm
Dinnu
Have you compared to another Defender. Steering on a Defender is not exactly precise, especially compared to modern cars. It is also normal to have considerable play once the steering is off center. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1037841 19th Jun 2024 8:19am
Page 2 of 2 <12
