Home > Technical > Excess play in steering |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10728 |
I have just had this, it started at the beginning of this week and i managed to get to my indy today so he could have a look, it turned out to be the new drop arm link, which i had to have for the mot, it was slightly lose, wobbled a bit, due to the paint wearing off, he said that they can do this, so he tightened it up and now it's all good 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
30th Nov 2023 10:15pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5804 |
Where exactly did it become loose Clayton? Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
1st Dec 2023 1:17pm |
Please oh please Clayton tell me you were "loose about his hoose"
https://youtu.be/qqCZe3WA-zE?si=1UziofpHTBIGbKsG When adverts were awesome I'll get me coat now... |
1st Dec 2023 1:30pm |
Sadly i remember that 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
1st Dec 2023 8:48pm |
Here you go Grenadier, hope this helps you Click image to enlarge 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
1st Dec 2023 8:51pm |
Rescue01 Member Since: 17 Jul 2015 Location: Aberdeen Posts: 98 |
I will need to keep a eye on that as I just replaced my drop arm recently
1st Dec 2023 10:44pm |
Pughey14 Member Since: 20 Aug 2016 Location: Leicestershire Posts: 5 |
Im just looking for some advice on the same subject.
I have a 2009 tdci done around 72,000 which has play in the steering. I have replace the following components over the past two years Radius arm bushes, drop arm ball joint, steering lower uj, track rod end ball joints, steering damper, wheel bearing. I adjusted the steering box and have had the tracking done. None of theses seemed to make any improvement. I took it to a specialist landrover mechanics who couldn’t seem to find any problem apart from a loose wheel bearing which when fixed seemed to make no improvement. The only thing I believe to still be the culprit would be the steering box itself…. Should this need replacing at such mileage? |
16th Jun 2024 4:35pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3396 |
Have you compared to another Defender. Steering on a Defender is not exactly precise, especially compared to modern cars. It is also normal to have considerable play once the steering is off center. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
19th Jun 2024 7:19am |
