Home > Puma (Tdci) > Clutch change / gearbox out - Tdci MT82.
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Good evening all,
My apologies if this has been discussed to death - but I'm looking for the quick/easy/short answer🤣
What bits of the interior need to be removed (or make it easier) to complete the job?
Post #1002029 27th Jul 2023 8:06pm
NickMc
Just the plastic tunnel to make it easier. Depends if you take the handbrake cable off or just take the drum off the back of the transfer box. I normally remove it whole and set it on top of the exhaust silencer, much easier to split the transfer off and replace the seal and splines on the adapter shaft.
Post #1002030 27th Jul 2023 8:24pm
MK
Loosening the handbrake base makes it so much easier. And of course the lid under the cubby box. Puma 110" SW
Post #1002039 27th Jul 2023 9:01pm
Mjibex
Thanks - so to be clear - none of the dashboard needs to come out?? Be it to clear any gearbox bellhousing bolts or floor/transmission cover panels.
I’ve heard some people say some of the dash needs to come out.. (I can’t see why - but I’ve never had to do anything other than a couple of ignition switches to my tdci)..
Post #1002045 27th Jul 2023 9:51pm
NickMc
I just take the whole unit off the back over the drive flange and keep it attached to the cable, I have done a fair amount of them Laughing
Post #1002050 27th Jul 2023 10:41pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
No non of the dash comes out or needs to be removed. As others have said just the handbrake cover, cubby box and front floor mats.
Post #1002088 28th Jul 2023 12:07pm
