Home > Td5 > Driver door water ingress
Lunar Landy
United Kingdom 2003 Defender 90 2.5 TD HT Bonatti Grey
My 2003 defender driver door has Ingress of water thru the roof lining at the top corner, I’ve visually checked the door seal it seems ok, any ideas? replace the door seal?
Thanks
Post #1001983 27th Jul 2023 11:43am
Screbble
Quite common. Could be any number of sources.
Do have a look for an hairline crack externally where the roof meets the gutter - a useful temporary fix there is the humorously named Capt. Tolley’s Creeping Crack Cure.
Good luck 🤞
Post #1001985 27th Jul 2023 12:07pm
Lunar Landy
Thanks, Thumbs Up
Post #1001987 27th Jul 2023 12:18pm
Harry.O
For me, it was the seam where the horizontal part of the roof meets the sloping part above the front seats. Captain Tollys worked for this issue.
It may be worth checking the join where the windscreen meets the roof and the top corners where the windscreen, roof and leading edge of the front doors all congregate behind the door seal. Sikaflex works well for the former and dum-dum putty behind the seal for the latter Thumbs Up 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #1002007 27th Jul 2023 2:17pm
Lunar Landy
Thanks all sorted, I used silicone as a temporary fix, which did the job, I have a similar issue although no leaks, where the roof meets the poly glass panelling (van type) there is a black bead, jointing, gasket? It runs around the full body at the top also at the bottom of the panelling where it joins the upper bodywork, it’s about 3 mm wide both are black in colour, unfortunately they are breaking down in some areas.
Do you know what this material is? And is it purchase part?
Regards
Big Cry
Post #1003081 5th Aug 2023 7:50am
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Here you go Luna Landy
https://www.ebay.co.uk/itm/193747210652?mk...media=COPY
I’ve sent you a PM as I believe we live in the same area
Jim
Post #1003103 5th Aug 2023 12:07pm
LR Nuts
.... or go to another eBay listing .....
https://www.ebay.co.uk/itm/155704240938?ha...R5T32dq4Yg
Good Luck
Post #1003104 5th Aug 2023 12:31pm
Just the drivers door leaking? think yourself lucky man!
Post #1003156 5th Aug 2023 9:12pm
Lunar Landy
Rolling with laughter Rolling with laughter
Post #1003336 8th Aug 2023 7:40am
