![]() | Home > Td5 > Driver door water ingress |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2122 ![]() ![]() ![]() |
Quite common. Could be any number of sources.
Do have a look for an hairline crack externally where the roof meets the gutter - a useful temporary fix there is the humorously named Capt. Tolley’s Creeping Crack Cure. Good luck 🤞 |
Lunar Landy Member Since: 02 Jun 2023 Location: Northamptonshire Posts: 39 ![]() ![]() ![]() |
Thanks,
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 720 ![]() ![]() ![]() |
For me, it was the seam where the horizontal part of the roof meets the sloping part above the front seats. Captain Tollys worked for this issue.
It may be worth checking the join where the windscreen meets the roof and the top corners where the windscreen, roof and leading edge of the front doors all congregate behind the door seal. Sikaflex works well for the former and dum-dum putty behind the seal for the latter ![]() 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Thanks all sorted, I used silicone as a temporary fix, which did the job, I have a similar issue although no leaks, where the roof meets the poly glass panelling (van type) there is a black bead, jointing, gasket? It runs around the full body at the top also at the bottom of the panelling where it joins the upper bodywork, it’s about 3 mm wide both are black in colour, unfortunately they are breaking down in some areas.
Do you know what this material is? And is it purchase part? Regards ![]() |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 902 ![]() ![]() ![]() |
Here you go Luna Landy
https://www.ebay.co.uk/itm/193747210652?mk...media=COPY I’ve sent you a PM as I believe we live in the same area Jim |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1258 ![]() ![]() |
.... or go to another eBay listing .....
https://www.ebay.co.uk/itm/155704240938?ha...R5T32dq4Yg Good Luck |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6158 ![]() ![]() ![]() |
Just the drivers door leaking? think yourself lucky man!
