![]() | Home > Modifications & Maintenance (L663) > How does it break, 3 years in? |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 ![]() ![]() ![]() |
Haven't had mine for 3 years yet to give any personal feedback. But I would say that any modern engine/gearbox going wrong at a bad moment wouldn't be an easy repair at the side of the road!
The Grenadier was touted as the 'proper' Defender replacement, but still uses a BMW engine and gearbox with their associated ECUs. I think the last Defender that you could fix properly by yourself at the side of the road would be the 300Tdi... |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 520 ![]() ![]() ![]() |
It will be fine, until it's not, then that's it, you'll need an army of computer engineers to diagnose and replace the sensors. Just like any modern vehicle. I'd agree that a TDI was the last one which could be truly fixed by the road, although relevant parts would be needed. Generally the older it is the simpler it is, but also much more likely to have worn out parts, which could decide to pack up at at the moment. Preventative maintenance is best, but sometimes a new cheap part is worse than an old good one.
As a new car, the new defender will most probably be ok, rugged an capable, but as an old one, well, I doubt it. Time will tell. |
ChasingOurTrunks Member Since: 19 Aug 2020 Location: Canada Posts: 89 ![]() |
Thanks for the feedback fellas.
Nick, I think you are right that most modern vehicles will have some challenging repairs at play. But, there are some that are very much walled gardens - for instance, in the motorcycle world, if a fellow owns a BMW Adventure Bike and they need to put a code reader on it, BMW won't actually sell you the software to do so. But, you can get an aftermarket GS911 software program that allows you to do most of the things the BMW software does and do maintenance at home. In contrast, my Triumph is OBDII compliant so a $20 dongle off Amazon allows me to read and reset (and effect the repairs) that trigger all the trouble codes. Another example - some manufacturers won't sell you the Factory Service Manual, which makes even basic maintenance and repairs very difficult. Again, the Triumph example - a FSM was just $150, and covers step by step (with pictures) every part, assembly, disassembly, and inspection. I suspect the Defender is more like the BMW, with a lot of proprietary bits that discourages the shade-tree mechanic, but I would be interested in hearing if the aftermarket has responded to better support the need. Mark - thanks for that feedback. I'm OK being my own "army of engineers", as I'm happy travelling with a laptop and a flurry of cables, and even throwing a box or five of spare sensors in the drawer for the bigger adventures where "fix it myself" is a requirement. I'm also happy to put a wrench to metal (or plastic!) in the garage to do my own maintenance in between trips. But, I'd rather not be a trailblazer here and instead know that other people have taken this approach before dropping $90k on it, and so far I've not seen anyone doing their own work which is to bad as this experience would greatly speak to the ease/challenges of bush fixes. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2712 ![]() ![]() |
There’s loads of stuff on the Facebook groups with people modifying and repairing. I’ve seen broken shock absorbers as an example.
The IID tool is likely to offer most of the plug-in diagnostics you’re likely to need. |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1833 ![]() ![]() ![]() |
looking at it from another angle - if they all lose around 30% of value in the first year or so (and they all will once the initial demand is satisfied and ex lease ones arrive on the second hand market) - buy the 35k ute, drive a bit more carefully and replace it every two years, you could afford to give it away and still be in profit!
Keith |
Thanks Retroanaconda, that's helpful. I got rid of Facebook years ago and don't do anything on it, but for the sake of learning more I think I will do a bit of a deeper dive into what's being done in those groups. I'll look more into this IID tool too. Thank you! |
That's a very fair point. To be honest my current Ute does everything I need, but barely. I need a few more places to put things in the cab, and a few more pounds of payload would be nice, but if money is the big barrier, I'll keep running what I have into the ground and replace it with something more or less the same. It's "Good enough" and then some. But, the other metric is "Smiles per Mile" which is important to me too, and the wagon kitted out for adventure brings me lots of smiles in between adventures when the vehicle has to be a regular utility vehicle. |
