Home > Td5 > Remove steering column UJs
excossack
I have some play in the top UJ for the steering. I have ordered a complete unit with new UJs and column as it appears UJs are not available for a 1999 column.
Is there enough room to slacken off top and bottom UJs and slide the column down off top splines and then slide back up? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #998360 3rd Jul 2023 12:06pm
geobloke
Yes there is room on the splines. The key is to make sure that the splines are clean and clear of rust and add some grease on to them to help the sliding part of the job.
It is worth soaking the locking bolts overnight in penetrating oil to help the job. You will need the LR No.1 tool to tap the UJs along the splines. Thumbs Up
Post #998362 3rd Jul 2023 12:25pm
Mdm
yep unlike the earlier tdi ones you can only buy the complete unit
Post #998369 3rd Jul 2023 12:50pm
excossack
Cheers both. 1999 Defender TD5 110
Regards
John M0VAZ
Post #998378 3rd Jul 2023 1:44pm
One thing that might cheer you up is that when I looked into this part a few years ago the TD5 version was massively less expensive than the nearly-identical TDCi version, which just has an added heatshield at the top end. That heatshield, as I recall, more than doubled the price of the part.
Post #998379 3rd Jul 2023 1:46pm
excossack
wow...thankfully I am on a TD5 Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #998380 3rd Jul 2023 1:47pm
geobloke
I am thankful I have a TD5 most days Rolling Eyes Bow down
Post #998382 3rd Jul 2023 1:51pm
A similar thing was observed with the fuel tank pick up, which on the 2.4 TDCi is identical to that on the TD5 except that it lacks the (presumably expensive) electric fuel pump.
Yet once again the pumpless TDCi part from those extortionate bandits at JLR was massively more expensive than the with-pump TD5 part, which led me to deduce that JLR must be paying some old codger to remove the pumps from TD5 parts to create TDCi parts, and the price hike is paying his wage.
Post #998397 3rd Jul 2023 2:53pm
geobloke
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
That made me smile Thumbs Up
Post #998400 3rd Jul 2023 3:08pm
It didn't have that effect on me when I needed a new one! Sad
I seriously considered buying a TD5 one and removing the pump! Then I though that the poor old codger has probably been relying on that income to feed himself, and the thought of him scavenging for worms got the better of me. Very Happy
Post #998401 3rd Jul 2023 3:13pm
geobloke
No I can imagine not Rolling with laughter I probably would have been tempted as well. For next time I suspect there are plenty of us TD5 blokes would have taken the pump off your hands Thumbs Up
Post #998402 3rd Jul 2023 3:15pm
excossack
Steering column replaced. Not too bad a job, around 45mins.
Its fair to say, there was some play
https://youtube.com/shorts/B2WjEuVeXZA?feature=share 1999 Defender TD5 110
Regards
John M0VAZ
Post #999028 7th Jul 2023 10:11am
geobloke
Blimey John that is quite the play Shocked Shocked I guess you now know why your Defender was wandering around the road Thumbs Up
Post #999031 7th Jul 2023 10:17am
excossack
Certainly was a fair bit of play. Hopefully now the steering will be a bit more precise...Well precise as Defender steering can get. 180 miles drive later today will tell me the results! 1999 Defender TD5 110
Regards
John M0VAZ
Post #999033 7th Jul 2023 10:19am
Hmm, that was properly knackered!
Post #999035 7th Jul 2023 10:31am
