![]() | Home > Td5 > Remove steering column UJs |
Yes there is room on the splines. The key is to make sure that the splines are clean and clear of rust and add some grease on to them to help the sliding part of the job.
It is worth soaking the locking bolts overnight in penetrating oil to help the job. You will need the LR No.1 tool to tap the UJs along the splines. ![]() |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1646 ![]() ![]() |
yep unlike the earlier tdi ones you can only buy the complete unit
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5925 ![]() ![]() ![]() |
Cheers both. 1999 Defender TD5 110
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17688 ![]() ![]() ![]() |
One thing that might cheer you up is that when I looked into this part a few years ago the TD5 version was massively less expensive than the nearly-identical TDCi version, which just has an added heatshield at the top end. That heatshield, as I recall, more than doubled the price of the part.
wow...thankfully I am on a TD5
![]() Regards John M0VAZ Econet Station 48 no clock |
I am thankful I have a TD5 most days
A similar thing was observed with the fuel tank pick up, which on the 2.4 TDCi is identical to that on the TD5 except that it lacks the (presumably expensive) electric fuel pump.
Yet once again the pumpless TDCi part from those extortionate bandits at JLR was massively more expensive than the with-pump TD5 part, which led me to deduce that JLR must be paying some old codger to remove the pumps from TD5 parts to create TDCi parts, and the price hike is paying his wage. |
![]() ![]() ![]() ![]() That made me smile ![]() |
It didn't have that effect on me when I needed a new one!
![]() I seriously considered buying a TD5 one and removing the pump! Then I though that the poor old codger has probably been relying on that income to feed himself, and the thought of him scavenging for worms got the better of me. ![]() |
No I can imagine not
Steering column replaced. Not too bad a job, around 45mins.
Its fair to say, there was some play https://youtube.com/shorts/B2WjEuVeXZA?feature=share 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Blimey John that is quite the play
Certainly was a fair bit of play. Hopefully now the steering will be a bit more precise...Well precise as Defender steering can get. 180 miles drive later today will tell me the results! 1999 Defender TD5 110
Hmm, that was properly knackered!
