Home > Maintenance & Modifications > Protecting her from the elements |
In your situation I would be looking at a car port as mentioned earlier. Could be done DIY or a nice green oak structure with shingle or slate roof if you are looking for aesthetics. It will essentially keep the worst of the weather and leaves off the vehicle, but not all of it. The other thing to think about at this stage is perhaps additional security such as lift up posts and security cameras as she will now be seen more easily.
3rd Jul 2023 12:07pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2532 |
Definitely check with your local Planning Dept. I found out the hard way that planning is a "black art". Ignore what the chap in the pub tells you. Find out from your local council if it is permitted development or whether you need planning permission. If converting your garage to residential accommodation - again you may need planning permission for change of use. Defender 90XS SW
3rd Jul 2023 4:06pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
…and building g control approval (for the repurposing of the garage to a habitable space).
3rd Jul 2023 4:11pm |
