- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
boxoftricks
Internal Chassis Corrosion Advice | |
I have a 1966 2a with an original chassis. Well original if you ignore the new bits and pieces welded on and patched
It's only for summer use so will be no road salt issues.
The exterior of the chassis will be stripped back and painted with Por15 rust prevention and then Por15 top coat over the rear cross member etc. Then I think just ACF 50 over the top (but unsure as of yet). No need to use Dinitrol etc as for summer driving and I would like to see any areas deteriorating.
My question is what's best for internal cavities? I'm sure there will be lots of rust etc in there so need something in an aerosol or similar I can spray in. Ideally with one of the long plastic tubes you can feed in. ACF50? I want to kill the rust before using a cavity wax.
1st Jul 2023 10:23am |
