Home > Series Land Rovers > Internal Chassis Corrosion Advice
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
I have a 1966 2a with an original chassis. Well original if you ignore the new bits and pieces welded on and patched Laughing
It's only for summer use so will be no road salt issues.
The exterior of the chassis will be stripped back and painted with Por15 rust prevention and then Por15 top coat over the rear cross member etc. Then I think just ACF 50 over the top (but unsure as of yet). No need to use Dinitrol etc as for summer driving and I would like to see any areas deteriorating.
My question is what's best for internal cavities? I'm sure there will be lots of rust etc in there so need something in an aerosol or similar I can spray in. Ideally with one of the long plastic tubes you can feed in. ACF50? I want to kill the rust before using a cavity wax.
Post #998153 1st Jul 2023 10:23am
kenzle8a
I believe Zagatos advice to his customers is ACF50 1st to kill rust then Dinatrol ML (the light brown cavity wax) after.
Post #998156 1st Jul 2023 10:53am
