![]() | Home > Modifications & Maintenance (L663) > Those guys from Stark are at it again. |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
Chuffin brilliant!! Sign me up for one!
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge This is the Inios variant. Flap falls down all the way, no restraint to hold level. ..... and a 2" receiver plate on tow bar, with optional 50mm ball. Has to be fitted by factory, then you get internal wiring loom. If fitted after vehicle built, can still fit tow bar ........ but NO wiring ...... WHY ??? |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1468 ![]() ![]() |
I wonder if you could adapt this with the boat hatch / box solution.
https://www.blackhawksolutions.co.uk/new-d...40QAvD_BwE Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
