Home > General & Technical (L663) > MHEV battery.
lightning
MHEV battery.
ls there any way to check the status of the MHEV battery on the 3.0 diesel?
The last MHEV vehicle l drove (Suzuki) had a little indicator telling you what was going on with it. On the Defender it appears to be invisible. l can't find any way to even check it's working.
Although l assume a warning message will appear if it stops working for any reason.
Post #997781 27th Jun 2023 6:33pm
Moo
Ukraine
I had it on my XC90. Interesting but of no real value. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #997807 27th Jun 2023 9:34pm
whiterdesign
If start stop works ok , MHEV battery ok . full Stop!!! 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #997814 27th Jun 2023 10:52pm
lightning
Well, l guess it's working then !!
Thank you. l didn't realise the start/stop depended on it.
Post #998109 30th Jun 2023 10:22pm
markb110
Only worry if you are the third owner…… Whistle
Post #998133 1st Jul 2023 7:53am
lightning
So when the MHEV battery fails the stop/start no longer works? Bring on battery failure!!
Post #998452 3rd Jul 2023 6:44pm
Nashvegas
United States
There is actually, sort of a way to look at the battery %, at least if you have a P400 gas motor and a Gap IIDTool.. I found a setting that shoes you the "MHEV battery charge %". I think there's a couple other readings showing "desired MHEV battery charge" and something else.
Oddly my Defender seems to keep mine "charged" around 53% or so. If I floor it or drive uphill rapidly, I watch the % go down. Then it'll go up above 53% if I'm not hooning it around.
Post #1003031 4th Aug 2023 3:59pm
