Home > General & Technical (L663) > MHEV battery. |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1352 |
I had it on my XC90. Interesting but of no real value. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
27th Jun 2023 9:34pm |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 269 |
If start stop works ok , MHEV battery ok . full Stop!!! 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
27th Jun 2023 10:52pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2734 |
Well, l guess it's working then !!
Thank you. l didn't realise the start/stop depended on it. |
30th Jun 2023 10:22pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2623 |
Only worry if you are the third owner……
1st Jul 2023 7:53am |
So when the MHEV battery fails the stop/start no longer works? Bring on battery failure!!
3rd Jul 2023 6:44pm |
Nashvegas Member Since: 25 Dec 2021 Location: Portland, Oregon Posts: 38 |
There is actually, sort of a way to look at the battery %, at least if you have a P400 gas motor and a Gap IIDTool.. I found a setting that shoes you the "MHEV battery charge %". I think there's a couple other readings showing "desired MHEV battery charge" and something else.
Oddly my Defender seems to keep mine "charged" around 53% or so. If I floor it or drive uphill rapidly, I watch the % go down. Then it'll go up above 53% if I'm not hooning it around. |
4th Aug 2023 3:59pm |
